THe radiator cap is supposed to be a slosh retainer, not a seal, it is open to the atmosphere and should be. It is a thermo siphon system and if ofer filled (like a modern car radiator) it will puke coolant and steam until it is at the correct level. (about 2.5 inches below the neck) If the coolant is covering the core with 1/2" to 3/4" it will be fine. Run it for a while with less in it to see if it is OK. There is no water pump, it circulates from density change cool radiator. hot engine. They work fine!!. If the block is filled with sediment and scale, or the radiator tubes are plugged badly, it will overheat. A radiator flush with vinegar, and removal of the water jacket plate to clean the block is about as far as needed. The hydraulics can be added with a pump mounted to the front (if it has battery start), or a belt driven pump added to the front of the engine. These take engineering skill but are possible. Leave the engine alone those numbers are OK. It is not a Kubota, or other new tractor, and they didn't pay close to those prices for it. So should they keep it. Not if they expect it to be a Kubota. Yes if they need a powerful limited pulling device, or are willing to have it upgraded to function as needed. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
