Re: SH Hydraulics Problem
Posted by Bob M on June 30, 2011 at 17:27:05 from (67.240.171.41):
In Reply to: SH Hydraulics Problem posted by RSCO on June 30, 2011 at 16:51:10:
Before you replace the pump here's a couple things to check:
1 - Make sure the Liftall lever is pulled all the BACK and latched. Also try holding the lever back past where the latch holds it and see if the hydraulics now work.
2 - If if the hydraulics still don't work solve it take a look at the 4-way remote valve ("Christmas tree" valve). An internal leak here will mimic a hyd pump failure.
