Re: Re: Re: CUB 8 VOLT WITH NEGATIVE GROUND
Posted by Dennis Dodds on August 08, 2000 at 16:08:55 from (38.27.1.2):
In Reply to: Re: Re: CUB 8 VOLT WITH NEGATIVE GROUND posted by george on August 08, 2000 at 14:26:47:
According to my Operator's Manual:
If the generator or the regulator has been removed or the leads disconnected, the generator should be repolarized. After the leads have been reconnected, but before the engine is restarted, proceed as follows: After making certain that the gounded battery terminal is the positive (+) one, momentarily connect a jumper lead between the "BAT" terminal of the regulator and the "A" terminal of the generator. This allows a momentary surge of current to flow through the generator which correctly polarizes it. Reversed polarity may result in vibration, arcing and burning of the relay contact points. Important! Do not touch the jumper lead to the "F" terminal on the generator, as this will damage the regulator. (The diagram shows the "BAT" terminal as the middle of 3 connections on the regulator and the "A" terminal as the top terminal on the generator. The "F" terminal is slightly down on the side.)
Post A Followup
: Re: Re: Re: Re: CUB 8 VOLT WITH NEGATIVE GROUND
