Re: BN
Posted by Lmack on July 02, 2011 at 20:43:12 from (74.190.19.181):
In Reply to: BN posted by Grumpydaniel on July 02, 2011 at 17:33:12:
You can find the SN stamped on the engine block. It is on the right side of the engine under the No. 1 plug. The B's, BN,s and A's all used the same engine number and serial number. If the engine is original, that would be the SN. Be sure to look for a stamped number, not a cast in number. There is a small flat area about 1 1/2 inches long and about a 1/4 inch wide.
  • Re: BN Lmack 20:50:32 07/02/11 (0)
