Posted by Pat-CT on July 02, 2011 at 20:43:37 from (68.9.37.25):
In Reply to: 59 cub lo-boy posted by cuttman on July 02, 2011 at 19:09:18:
How is the compression? is the timing correct? If you sue ether will it even attempt to start?. After you crank it with no success if you pull the lugs out are they wet? 3 things you need to make an engine run are compression ignition and fuel. Is the spark a good blue color?
What size batter cables are you using- perhaps your getting enough voltage to turn it over but not enough to get power to the coil. How is the battery. Check the plugs for gas after trying to start it Check compression on all four cylinders. Check timing If you have spark I doubt it has to do with the starter switch, if its turning over.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
