Re: Farmall H and M Spark Plugs
Posted by Owen Aaland on July 02, 2011 at 20:45:37 from (216.47.33.237):
In Reply to: Farmall H and M Spark Plugs posted by SadFarmall on July 02, 2011 at 19:28:55:
Going with Champion Spark Plug numbers, the original standard plug was a D16. That was then changed to D15Y. The plug has about the same effective heat range because it is one heat range colder but with an extended tip plug. The plug for light duty was D18Y. After leaded gasoline was phased out Champion changed the recommendation to D15Y for heavy use, D18Y for standard duty, and D21 for light duty.
Because the D21 is a pretty hot plug it can causes problems if used for heavy duty use. It can cause preignition if it runs too hot.
I use D21s in my I2444 with good results but that engine (C-153) is rarely used at more that about 2/3 throttle and light load. On my Super C with a 6 foot Wood mower I run D18Ys because that engine runs under much more load.
