Re: super H sleeve
Posted by rustyfarmall on July 03, 2011 at 05:46:31 from (216.248.71.224):
In Reply to: super H sleeve posted by Pat-CT on July 02, 2011 at 17:21:55:
I don't know, but he did say the sleeve fit in the bore, but just wouldn't go down far enough. A Super H sleeve is enough larger that it won't even begin to fit into the bore of a C-152 Farmall H engine.
