Re: Farmall Cub Stopped
Posted by El Toro on July 03, 2011 at 16:59:53 from (108.15.86.54):
In Reply to: Farmall Cub Stopped posted by RFR on July 03, 2011 at 11:50:00:
Bring No1 piston to TDC on the compression stroke
then remove the cap and see where your rotor is pointing. If it's not at the No1 plug tower your timing is off. One other thing is to remove the cap and have someone crank over the engine and see if the rotor is turning. Hal
