Re: 1486 clicking noise
Posted by Owen Aaland on July 03, 2011 at 19:32:06 from (216.47.33.237):
In Reply to: 1486 clicking noise posted by 1486 james on July 02, 2011 at 08:11:33:
If it was in the PTO gears the noise would be present even when the clutch is released.
It would be nice to know if the noise is still there if you have the speed transmission between 2nd and 3rd. In that position the only gears meshing are the TA and counter shaft gears.
It sounds like your other failure is the drive hub and IPTO shaft in the pressure plate. If you haven't taken it apart yet you may trying to put a piece of wire or cotter pin in between the gear and hub and make it turn enough to do some more testing.
