Re: IH 340 Utility Gas - Gas runs our of carb air inlet
Posted by old on July 03, 2011 at 21:35:07 from (209.86.226.40):
In Reply to: IH 340 Utility Gas - Gas runs our of carb air inlet posted by John Ratu on July 03, 2011 at 20:39:00:
Well #1 you should always shut off the gas valve when you park a tractor. That said sounds like you have a rubber tipped needle valve and it needs the have a set put in it. Ya it will over time set it self but you can do it also by opening up the carb pull the float and then drop the need in the seat and tap on it a few times with a small punch etc. No need to hit it hard just a couple light taps to put a set in the needle tip
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
