Re: How to remove stuck rim from center on an H
Posted by Tom Fleming on July 04, 2011 at 06:36:29 from (206.193.247.2):
In Reply to: How to remove stuck rim from center on an H posted by Zachary Hoyt on July 03, 2011 at 16:00:14:
In addition to cleaning out the debris, I have a 5 lb. brass hammer that I have used in this situation. a bit of penetrating oil on the rust, such as PB blaster. Be careful if you are using a regular sledge or similar. you will deform the cast and if you hit is too hard, can break it.
It would also be handy if you have a way to put some "down" pressure on the center, and then work your way around at all the "touch" points. if you have a front end loader or similar, put a little down "push" on it.
This post was edited by Tom Fleming at 06:40:21 07/04/11.
