Re: Farmall drive train?
Posted by Stuart on July 04, 2011 at 10:21:34 from (64.198.86.189):
In Reply to: Re: Farmall drive train? posted by The tractor vet on July 03, 2011 at 22:11:38:
Well there is a reason they went away from dry brakes, we have hill around here, try stopping a 34,000lb manure spreader, you can smell the brakes.
Send me a weight slip and a video of it pulling that dmi and I will believe you. We had a 220 hp 1466 that would pull a 9 shank glencoe chisel plow faster than high 1. Need a front wheel assist. Usually takes 75 hp per shank so I think your a little on the full of it side or cant read a tape measure. What type of wagons did you use to haul silage in. Our neighbor has 20ft miller pros combo boxes and you have to work damn hard to get 10 ton of corn silage in them.
