If this tractor had ever been under a high drum picker, the most noticable thing you would see would be flange type rear axle housings (if they have not been removed). These flange type housings are used to mount the bull gears which both raise the tractor and reverse the direction of operation of the tractor. The high drum pickers had picking heads with bars that had 20 spindles each. In contrast, the low drum pickers had bars with 14 spindles each and reversed the tractor direction by changing the transmission top shift forks and flipping the differential.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
