Re: Farmall A axle questions
Posted by Jim Becker on July 04, 2011 at 15:39:56 from (173.57.144.251):
In Reply to: Farmall A axle questions posted by Rick(MN) on July 04, 2011 at 12:28:58:
Quoting Removed, click Modern View to seeProbably the drain hole. Tilting the tractor with the jack probably allowed oil that had already leaked past a bad differential shaft seal to get out. If it isn't a big leak, I wouldn't do anything about it.
Your noise is probably a loose rim at the wheel center, loose wheel center at the axle or loose wheel weight. Make sure all bolts are tight.
