Re: STUCK IN TWO GEARS?
Posted by Rich Cota on August 09, 2000 at 04:04:18 from (198.56.12.237):
In Reply to: STUCK IN TWO GEARS? posted by JIM on August 09, 2000 at 03:55:09:
Jim, You need to take the shift lever out and take a large screwdriver or other pry bar and line up the shift rails. When you look down the shift lever hole you should see the shift rails clearly. This is caused by the end of the shift lever becoming worn too short. You need to get a little bit welded on the end and file it off square again.
Post A Followup
: Re: Re: STUCK IN TWO GEARS?
