Re: Farmall cub magneto
Posted by El Toro on July 04, 2011 at 19:05:25 from (108.15.86.54):
In Reply to: Farmall cub magneto posted by Dick H in NY on July 04, 2011 at 14:13:19:
Did you pull the mag off the engine? If you did and didn't note where the rotor was pointing
your mag may be out of time. To check to see if it's out of time bring No1 piston to TDC on the compression stroke. Then remove the cap on the mag and see where your rotor is pointing. It should be pointing to the No1 plug tower.
Before you do this check, rub your new points with some 320 wet or dry and then see if you have fire to your plugs. Make sure your points are set at .020" on the high point of the lobe. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
