4 cyliners minus 1 cylinder
Posted by bill boucher on July 05, 2011 at 06:38:29 from (75.253.220.0):
I have a international 3444 backhoe. The bearings on the #3 Piston seized and threw a rod thru the block. The machine might be used 30 hrs a year. ( bury an ocasional animal, Move a down tree, ect.). It is an old tired machine. I have to put hydraulic fluid before i use it. My question is for the time being (unTILL this winter when it cools down some) Can I leave the rod out, Attach the piston to the top of the cylinder, Plug up the Fuel Injectot, unplug the Glow Plug , Put a Plate over the hole in the block, and use it on three cyliders. I am trying to buy some time till this winter when I will rebuild another block. I know it will run a little rough but will it work. Thanks Bill
