Posted by rustred on July 05, 2011 at 10:18:00 from (74.200.18.156):
In Reply to: Re: Tow adjustment posted by rustyfarmall on July 05, 2011 at 08:51:10:
if you set toe-in at 1/8", or 1/4", it will remain that way whether the tractor, or car, truck, is parked or rolling down the highway. NOT SO... on a Rear wheel drive vehicle , the front wheels are pushed and tend to toe out. tie rods, idler arms have built in spec's which allow this.once running down highway the wheel are running parallel to each other and should be at zero toe in. on a Front wheel drive, the front wheels tend to pull themselves forward and create toe in. that is why they are set with a slight toe out or close to zero. toe in enhances staight line stability. positive caster also enhances straight line stability.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
