Re: 3 pt. for SMTA
Posted by Nate V. IA on July 05, 2011 at 14:09:12 from (173.215.42.82):
In Reply to: 3 pt. for SMTA posted by duckguy on July 04, 2011 at 13:11:51:
I have a Saginaw on my 450, handy as a shirt pocket. You don't have to worry about tearing up this one, there isn't enough tractor in front of it. I can pick up 1500 lb hay bales, any more and it picks the front of the tractor up. I have also picked up the rear tires then used cribbing to hold it while I changed a tube.
There is no draft control with this setup, but you can pull two pins to make the 3pt float. If you're thinking about getting a 2 or 3 bottom 3pt plow forget it, it doesn't work worth a hoot. I have my original swinging draw bar and the 3pt doesn't interfere with it.
Nate
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
