Re: Farmall H antifreeze in oil
Posted by Ed Flywheeler on July 05, 2011 at 15:04:09 from (71.101.55.146):
In Reply to: Farmall H antifreeze in oil posted by Ed Flywheeler on July 04, 2011 at 17:09:56:
third party image
third party image
Update; after removing the cover, timing gears and engine plate, I found a freeze plug directly below the water pump. Plug had a quarter inch crack. Had to shell out .79 cents for a new one. Always the way it is. Thanks for the help.
