Re: Putting F-20 flywheel back on
Posted by J.J. from Afton on July 05, 2011 at 22:21:07 from (99.125.109.72):
In Reply to: Putting F-20 flywheel back on posted by Evan Mellott on July 05, 2011 at 05:46:57:
It helps if you have an oven you can use to heat the flywheel so it slips on easier. Otherwise what I did with my Regular is I used bolts that I tightened into the block to pull the flywheel on. Just make sure you line up the hole in the process and drive the pin in afterwards. Helps to have assembly lube for the flywheel and the pin. And it also helps to have a bolt threaded into the pin as well so the pin is not hammered while being driven in.
third party image
third party image
