Re: Farmall M Carb Rebuild
Posted by Hayfarmer on July 06, 2011 at 06:55:58 from (71.80.197.209):
In Reply to: Farmall M Carb Rebuild posted by dorsure on July 06, 2011 at 06:45:44:
Sounds like needle is stuck down. Float may be hanging up on the inside of the carb housing. You can take it loose without removing carb and drop it down to see what is going on. Thee is a filter on the inlet to carb also. Have you tried to start tractor? I have had trouble getting fuel to fill sediment bowl even until you roll engine over, it seems to air lock.
