Need help Identifying an unknown international
Posted by Dcoble67 on July 06, 2011 at 14:31:49 from (67.142.165.29):
Dad bought a international tractor. It has a wide front end, 16 inch tires on front, 24 inch tires on rear, a four speed transmission, "the right top of moter has the casting C 123, so I think its a 123cid engine. The ID tag says serial 5129 J but the model is beyond reading cause it was not stamped like the serial.. The date code on other side or right side we cant make out. Any ideas? Thank you in advance.
