Hi Pete7, I have read the story in the link you suggested. I actually read it again and realized that my question / request for a flow description is to vague. What I am asking is where the fluid goes when it leaves the pump. Just simply, not each port or every turn but just simply from each part to the next.
Example, from pump to pressure relief, safety valve to .......
NOTE: If possible, I would like to understand if the flow direction changes when the control lever is moved from up, down and after a desired position is reached and low pressure state is achieved. I realize the flow will change inside the pressure relief, safety valve itself and that does not need to be mentioned. Only an explanation of flow from one component to the next in each control lever position. Thanks, Tod.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
