Re: New carb vs rebuilt carb?
Posted by oldtanker on July 06, 2011 at 20:37:24 from (66.228.255.223):
In Reply to: New carb vs rebuilt carb? posted by Mr Farmall on July 06, 2011 at 16:51:59:
Ops forgot....on that sized engine just how much of a performance gain are you going to expect? Some upgrades can give as much as a 25% boost in HP. But not just a carb. So maybe 5-10%..... maybe less? On 16 HP???? You wouldn't even notice it! I wouldn't even bet on 5% without a better intake and exhaust. Just don't believe the hype! Knew a guy who had a dead miss in his car. He did a tune up using Split Fire plugs and wires. Man was he impressed! Just didn't understand that the difference was maybe because it was now running on 8 instead of 7. I'll bet he's still using Split Fires!
You may be better off buying a used carb and rebuilding it yourself.
Rick
