cub carb floods
Posted by ccaissie on July 07, 2011 at 03:22:49 from (68.238.52.18):
Cub runs well after rebuild, but stalls and then leaks gasoline. I figure I've got junk in the float needle valve which stalls it, then prevents the valve from closing.
Or it's haunted. I'll check carb before I call the exorcist.
