Posted by Indiana Ken on July 07, 2011 at 04:30:54 from (66.249.229.176):
In Reply to: Turbo question posted by 1949H on July 06, 2011 at 20:32:40:
You stated that you were stuffing the carb. I take this to mean you simply removed the air inlet plumbing from the air filter and connected the turbo discharge to the inlet if the carb. As previously mentioned this will not work since the carb fuel bowl is vented and the venturi is now being pressurized. Typically the entire carb is placed in a sealed box and this box is pressrized by the turbo or supercharger. The throttle, choke and fuel lines must be sealed where they enter the pressurized box. As mentioned this is the approach used by Studebaker, Ford and others for the McCulloch/Paxton supercharger equipped models.
Once the carb is placed in a pressurized box it operates the same as when the atmospheric pressure (barometer reading) changes. That is to say the mixture will be richer at low atmospheric pressure and more important it will be lean at high atmospheric pressure. If you keep the bosst pressure to a few Psi you can simply set the mixture on the rich side and live with it being rich when not on boost. If you intent to run higher boost pressures you will need some way of adding more fuel at high boost. The reason this happens is because a carb can not determine the density of the incoming air - the turbo pressurizes the air which increases the density. One final note the fuel pressure must be higher than the maximum boost pressure otherwise fuel will not enter the pressurized box.
Should you decide to add the carb to the inlet of the turbo (suck through) you will need a turbo designed for this application. The turbo oil seals must be designed to operate under an inlet vacuum which of course is not present on diesels.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
