Re: weight ??
Posted by Phil Auten on August 09, 2000 at 11:21:02 from (206.175.72.226):
In Reply to: weight ?? posted by Allan on August 09, 2000 at 11:13:59:
Allan,
the tractor weighs 4,365 lbs. per Guy Fay's book and I would add 2,500 more for the loader and hoe.
That adds up to 6,865 lbs. Go for at least an 8,000 lb. gross trailer, 10,000 gross would be better for a good safety margin. That way if you get a bigger tractor later, you can still use the same trailer. Also, if you carry any parts, tools, accessories, fluids, etc. you have the capacity you need.
My 2¢,
Phil
Post A Followup
: Re: Re: weight ??
