Re: Farmall 706 Amp light on
Posted by bermuda ken on July 07, 2011 at 13:48:58 from (50.50.17.146):
In Reply to: Farmall 706 Amp light on posted by scottsphere on July 07, 2011 at 07:34:52:
Might you have a pinched/cut wiring harness???
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
