Re: 460 Diesel Hydraulic flow description
Posted by Tod Michigan on July 07, 2011 at 16:29:43 from (75.219.86.112):
In Reply to: Re: 460 Diesel Hydraulic flow description posted by Bud DeLong on July 06, 2011 at 17:50:47:
Hi Bud Delong, I'm certainly NOT an expert on the issue but I had a few thoughts about your question. The spool valve for the Tele-depth system should not be used for a remote set up because it needs feedback from a follow up linkage to put the system back in a low pressure bypass mode.
Not sure if this answers your question or not but thought I would offer an answer for you.
Tod.
