Hi Pete23, I wanted to let you know what happened. As I mentioned earlier, I removed and inspected the pressure relief safety valve and also the check valve today and when I first started up, it seemed to make the same surge noises, but after running the lift up and down several times it seems to have straightened out. I will let you know more about that after I run it for a while. I DO HAVE ANOTHER QUESTION for you or anyone who may have done this. I'm having problems with my power steering(PS) and need to do some testing. I've been told to put a shut off valve in the pressure line and I see no way to do this without cutting the steel line. My question is, after I cut this steel line will a normal compression fitting hold the pressure that the PS pump puts out? If not, what else can I do to install the test valve so I can test the pump? Thank again, Tod.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
