Re: Charlynn Problem Help!!!!!
Posted by pete 23 on July 07, 2011 at 18:22:16 from (74.32.234.149):
In Reply to: Charlynn Problem Help!!!!! posted by Bob Frazier on July 07, 2011 at 10:59:40:
Does the torque generator have a nice smooth feel with out engine running. You should be able to feel the valve mechanism moving. That is the free play in the unit itself that I am referring to. That first little movement of input shaft without any movement of output shaft is the valve moving to direct flow internally.Then, does it turn smoothly with front wheels off the ground and engine not running. Other thing is , what flow divider valve did you hook up to your live power pump setup.
