Hydraulic Surge only stops when....
Posted by Tod Michigan on July 07, 2011 at 20:01:42 from (174.252.224.132):
Hi guys, having problems with my Tele-Depth 2 point hitch system on my Farmall IH 460 Diesel. I'm getting a hydraulic surge that has a steady rhythm to it. It is the hydraulic pump that I replaced last fall and I don't want to damage it. It quits if I move the lever up or down as long as the lift is moving. Then when the lift has found its position the noise starts again. The only other thing that makes it quit is to move the control lever SLIGHTLY in the down direction. Then the noise stops for a while. If/when the noise returns, I can make it stop by moving the control lever in the downward direction SLIGHTLY again, like I'm following the problem down. If I put the lift all the way down, with the lever in the full down position, the noise is there.
I'm lost. I just today removed the check valve and the saftey valve and inspected them and didn't notice anything wrong with anything.
I need some direction, PLEASE.
Tod.
