Posted by mkirsch on July 08, 2011 at 05:13:04 from (64.80.110.75):
In Reply to: brake adjustment posted by Ed Storey on July 08, 2011 at 04:39:26:
There is one adjustment for the brakes, that "ball nut" on the front where the rod comes out to connect to the pedal. Usually that doesn't make any difference.
What you need to do is take the brakes apart, clean them up, replace the fiber disks.
The standard hydraulic pump on the tractor is on the right side of the engine near the front. There is no "PS pump" on top of the transmission.
Backhoe attachments will either run the pump off the front of the engine, or off the PTO.
Obviously, oil is leaking, but not from a pump if it's ON TOP. There's no easy adjustment to make it go away. A seal/o-ring/gasket has failed and needs to be replaced. You're just going to have to take whatever this is apart, see what's wrong, and fix it.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
