Re: 10-20 - Exhaust valves
Posted by pete 23 on July 08, 2011 at 09:53:05 from (74.32.234.149):
In Reply to: 10-20 - Exhaust valves posted by kevin LA-CA on July 08, 2011 at 05:11:36:
I know nothing in particular about a 10 -20 but will say normally an exh valve is a different material but not always. If you put those valves on a valve refacer you can tell by the sparks if material is different or not. In fact, I used to change wheels on the valve grinder if I had to reface the stellite valves to get a nicer finish. Was kind of hard on stone life as you always have to dress stones more when changing back and forth between different ones.
