Don't know whether you have the operators manual, but it states to use only straight 30 wt low ash oil. The oil pump on cub engines is located on the back of the cam shaft well above the oil level in the pan. As far as leaks are concerned, my 184 has had the same problem as yours. I had to replace the aluminum casting that holds the seal, as well as use a speedy sleeve on the cranshaft.
Repairs can be made without removing the engine. If you need help my email is open. Joe
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
