Posted by Janicholson on July 08, 2011 at 11:16:41 from (199.17.6.66):
In Reply to: New to me posted by VAJerry on July 07, 2011 at 16:40:41:
As stated,the coil is original. With the tractor running, measure the voltage at the coil terminal going to the ignition switch (not the distributor) if it reads 12+ volts, that coil needs a dropping resistor (mid 60s Chevy, or Chrysler ballast resistor will do it). The coil should be attached to match the battery ground. (it is probably backwards now) The Negative coil terminal should go to the distributor (where it finds ground through the points) Positive to Switch. Very nice Tractor. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
