Posted by D Slater on July 08, 2011 at 17:27:44 from (184.15.35.247):
In Reply to: Belt Pulley Lever SM posted by TV Iron on July 08, 2011 at 15:09:29:
Intended IH way was on the brake pedal side up to and including tractor serial # L 504801. Higher serial numbers went on the clutch pedal side. Different boxes were installed or added over the years, so you may find different than above. Above serial 504801 also used a starter and choke pull rod in the same bracket above the clutch pedal on non diesel tractors whether or not is has a hydraulic tank under the gas tank. Should have battery box under seat also.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
