Re: 666 Unloading Valve Help Please
Posted by pete 23 on July 08, 2011 at 19:39:23 from (74.32.234.149):
In Reply to: 666 Unloading Valve Help Please posted by in-too-deep on July 08, 2011 at 18:42:12:
If you have the piston out, blow it out real good as there is a small orfice in it, check to see that it still has spring tension on pin of piston, put on a new o-ring and try it. Try to look in at the ball and seat to see if any foreign material is under the ball. The o-ring is a special S treated o-ring, they always had the part number stamped right on the o-ring, don't know if they still do. If you have to take out the whole draft control valve and cyl it isn't all that bad, just some pesky linkages to contend with.
