Re: IH Super A steering play advice needed please.
Posted by gene bender on July 08, 2011 at 19:43:21 from (207.177.56.53):
In Reply to: Re: IH Super A steering play advice needed please. posted by tractorfacter on July 08, 2011 at 06:02:30:
SA used the nut and the shaft is tapered. Earlier oned used the square out-put shaft. Check your steering shaft for end play cause if the bearing on the end of the worm has play it will give steering wheel plenty of free travel. You can tell if its worn when you turn the wheel see if the steering shaft has end play. There is also a bearing in the sector and some bushings also look for play if the woodruff key is loose on the gear. The worm and gear usually arent bad.
