Re: 6 volt +gnd coil replacement question, 4 to 3 wire
Posted by Xyphor on July 08, 2011 at 21:21:15 from (141.157.95.144):
In Reply to: Re: 6 volt +gnd coil replacement question, 4 to 3 wire posted by Janicholson on July 08, 2011 at 20:20:38:
Thanks for the reply.
I'm pretty sure the way I intend to hook this up is correct...I'm an electronics geek, but it hurts my brain trying to visualize a positive ground system. My concern is that technically I'll be hooking the primary side of the coil up backwards to battery polarity (ground to - and negative to +). Ugh, there goes that headache again.
