Connect the (-) to the ignition feed from the switch. Connect the (+) to the distributor points/condenser. The remaining lead should be the secondary led to the distributor cap.
Was your old coil from a magneto? I don't belief I have ever seen a battery ignition coil with four separate leads.
Electrically you cannot connect the primary leads, one to the ignition switch, and the other to ground, and have it work.Since you are working with DC current rather than AC in order for the magnetic lines of force to change to induce voltage in the secondary winding the primary winding must be turned on and off. That is the job of the points which must be connected to the grounded side. With the switch on and the points closed the current will flow through the primary winding and build up the magnetic field in the coil. When the points open the current flow stops in the primary winding which causes the magnetic field to collapse. The collapsing magnetic field induces the current in the secondary winding which will jump the spark plug gap when the voltage gets high enough.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
