Owen, Pete 23, Somebody? 1066 Injection Pump?
Posted by Allan In NE on July 09, 2011 at 05:39:50 from (148.66.88.254):
The other day I noticed a damp area on the forward body of the injection pump. Tiny little square headed 1/8" plug or some such thing down under the small side cover of the pump.
Got busy and forgot about it.
Last night when I parked the tractor, I see I've got engine oil all over the left side of the forward part of the left frame rail and front end. Little plug is gone; just a gapping hole in the pump.
Is that little guy just a tiny pipe plug? Going into an oil feed galley on the pump?
Tractor runs good and with good oil pressure when I shut 'er off.
Thanks,
Allan
