Re: Farmall M Diesel
Posted by Cub Man on July 09, 2011 at 05:50:23 from (204.15.156.96):
In Reply to: Farmall M Diesel posted by Cub Man on July 07, 2011 at 20:56:00:
Thanks for the info. I will go back and and look for the ID #s stamped in the block. Tractor starts and runs well, has like new rear rubber, IH wide front, fenders, pulley and 1 set of weights. The minuses are the power steering leaks fluid pretty fast, the belly pump needs repair, and the radiator has a small leak but the fluid in the radiator is clean no traces of oil or sludge while engine is running. Seller is asking 2750.00
