Re: What am I missing?
Posted by Bud DeLong on July 09, 2011 at 06:48:44 from (205.188.116.73):
In Reply to: What am I missing? posted by Livin the Dream on July 09, 2011 at 05:50:31:
I would remove the spark plugs and put a spoon full of gas in each plug hole.If the engine fires a few times but no start i would pull the breather hose and hold my hand over the carb inlet. You should feel a strong suction! If not you may have stuck intake valves of maby a intake manifold leak? Gas might run out of a carb but it has to be sucked into the cyls to run.Bud.
