Re: Timing a 10-20
Posted by rustred on July 09, 2011 at 09:42:15 from (74.200.18.156):
In Reply to: Timing a 10-20 posted by F-Dean on July 09, 2011 at 09:06:48:
locate TDC by putting thumb over plug hole then crank till you feel compression pushing out. then use a pop straw or piece of wire and crank slowly till you can feel piston coming to tdc.
when i have the valve cover off i just watch the running mate #4 cyl. so that the rockers are on the rock and you know #1 is on compression.
