Posted by Livin the Dream on July 09, 2011 at 11:18:15 from (71.214.150.252):
In Reply to: What am I missing? posted by Jim Becker on July 09, 2011 at 07:45:30:
Just to back up a bit... I also have completely cleaned the carb, dumped the tank fuel and seditment bowl and cleaned out the gas line. I know it has good compression, how good not sure but doubt that is my issue. I have no air hose between air cleaner and carb at this time...don't think that would keep her from starting but not sure? As far as timing... I have not been able to locate the notch or any indicator line to set the timing off the clutch plate that they refer to unless I'm just blind....I certainly could be missing it but not sure exactly where I should be looking beyond that..... thanks for all the tips... we will keep working at it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
