OK with the coffee, but wait on the humble pie. A web site, cngco dot com, referenced in other posts on this site has a diagram for Farmall 140.
In looking at it I see two things that would lead a person astray.
(1) The battery is shown negative ground, but the coil shows positive post to distributor. With negative ground, coil negative goes to distributor.
(2) The coil to distributor connection is poorly drawn. It shows wire from coil going to side of distributor, but the diagram does not show a feed through at the side of the distributor. The line goes to the circle representing distributor and has a ground symbol also connected to the circle. This would indicate that the coil connects to the grounded distributor case. Diagram needs a feed through indicator
Several other diagrams in that series are incorrect. F 240 gas diagram also has battery-coil polarity mismatched and shows positive coil connection going to a spark plug outlet on the distributor cap.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
