Re: Need help installing Planter Drive Gear onto Hybrid F...
Posted by RTR on July 09, 2011 at 11:52:46 from (74.248.177.118):
In Reply to: Need help installing Planter Drive Gear onto Hybrid Farmall posted by RTR on July 09, 2011 at 10:30:27:
Ok, here's the deal. I thought about looking at the parts breakdown on Case/IH website, and found how it is attached, or what the parts consist of. I went to inspect my other Super A tractor, and the seal with retainer was held on by (4) 9/16 bolts. After that was taken off, you could remove the big center bolt inside the "bushing" as the website calls it. Once that was removed, the bushing just slides off.
When I was installing the assembly onto the Super A "Hybrid" tractor, I found a steel ring (probably just for protection) sitting around the keyed drive on the final drive. I removed that ring, and the assembly bolted right up!! Now I can mount the planter to the Hybrid Super A tractor! I HOPE THIS INFO HELPS SOMEONE OUT IN THE FUTURE!
