Re: Farmall 706 Amp light on
Posted by Owen Aaland on July 09, 2011 at 16:16:14 from (216.47.33.237):
In Reply to: Farmall 706 Amp light on posted by DanR on July 07, 2011 at 07:34:52:
The TA lube pressure light shares the same bulb as the engine oil pressure. the charge indicator bulb is all by itself.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
